If you click “Wireless Networks” show all APs separately along with their MAC addresses, and corresponding signals, even if same SSID.
Have an option to click “Connect” to a specific AP MAC address (which in turn will make it the “Preferred BSSID”)
When viewing the “Details” page, list the AP MAC address Under IP address (or near it), currently there is no way I can see where you can tell which AP you are connected to
That is partially what I was asking for… now if there can be connect buttons for each unique MAC address, one can select which AP they want to connect to (I guess prepopulate the preferred BSSID?). Right now there is only one connect button.
yes, i understand that is currently how it is, but i am asking if there can be multiple connect buttons so one can choose to connect to a specific AP/BSSID and have that BSSID saved in the BSSID field?
When you have the preferred BSSID defined, the WiFi WAN will try connect to the specific AP first before will connect to other AP. You need to configure multiple preferred BSSID for the single SSID ?
