Feature Request:
When the USB-Eth WAN is configured as a lower priority WAN i.e priority 2 it is put into a “cold-standby” state where it does not have an IP or so on.
This lengthens failover times in the event of a primary WAN failure or where the USB-Eth is being used to bring in a low speed FTTC/DSL connection via PPPoE.
Could the USB-Eth functionality be enhanced to allow the WAN to be configured to stay active when in a lower priority such as the behaviour of cellular links or regular Ethernet WANs.
I know it is easy to work around this by leaving the WAN in priority 1 and using outbound policy and overriding relative priority on the PepVPN profiles but it adds another step of configuration to consider.
