Just testing my first PepVPN connection. Is the easiest way to enable / disable the PepVPN connection on the BR1 mini to go to Advanced, click on the pep vpn profile, and then uncheck enabled. Then apply changes?
Under that I have “send all traffic to: thevpnprofliename” checked.
Does it make a difference if I leave that checked when the vpn is disabled? It seems to work, but I’m curious what leaving that checked when the vpn is not enabled does.
The help item is hard for me to understand for that “Help
You can send all traffic to a PepVPN profile that with only one Remote ID defined, also “Allow shared Remote ID” and “NAT Mode” should be turned off.”
