Q: Do Peplink devices support eSIMs?
Peplink’s new Bring Your Own (BYO) eSIM feature allows users to use their own eSIM and data plan with our devices. The only requirement to use this feature is that users need to have an active CarePlan subscription. If you want to get a head start, you can test it out now by downloading our 8.4.0 firmware here.
Q: How many eSIMs per device?
The number of eSIMs that you can use in your device depends on the number of cellular modems that are built-in. For instance, since the Transit Duo has two cellular modems, therefore, it is capable of using two eSIMs.
Additionally, each eSIM can store up to two profiles, allowing you to further expand and unlock the cellular potential of your device.
Q: Which devices support eSIM?
As of Aug 25, 2023, the following devices are eSIM compatible.
BR Series: MAX BR1 Pro 5G, MAX BR1 Mini, MAX BR1 Mini Core, MAX BR2 Pro
X Series: Balance 310X, MAX MBX Mini, EPX, Balance 20X
HD Series: MAX HD2 MBX, MAX HD4 MBX 5G, MAX HD4 MBX, MAX HD1 Dome Pro, HD2 Dome Pro, Dome Pro Duo, Dome Pro LR
PrimeCare Series: MAX Transit Duo Pro E, MAX Transit Duo Pro , UBR Plus
MAX Adapters: MAX Adapter LTEA, MAX Adapter 5G
FlexModule Plus/Mini: Flex Module Plus, FlexModule Mini.
You can find an up-to-date list of eSIM compatible devices here.
