I have a little question about multiple SIM Cards slots for failover purpose.
Well this docs says when you added second SIM Card on failover slot you can use two configs.
1º - For failover when primary carrier down.
2º - for control your data transfer plan. (redux costs)
My question is:
The switching between slot one and failover is automatic for different carriers? (fictitious exemple VADAFONE and AT&T)
Or I need reconfigure informations about APN on pep devices when use two different carriers on principal and failover slot?
If automatic or applicable in installation moment ok is perfect for my application!!!
Else, ok works but need reconfiguration in run time.
Sorry to interrupt this tread
But actually I have wondered about which criteria the BR1 looking into for failover between sim A and B ? Is it just when the preferred sim loose total signal or is there any possibilities to adjust some criteria ?
I think maybe to tell the unit, that if SIM A comes below -110 dBm, it switch to sim B or if Latency is above XXX ms ?
