Hi all,
I have a PePLink 210 (revision 1) with firmware 5.3.9. with 2 WAN link connection running in drop-in mode.
WAN 1 IP address is 1.1.1.0/27 (example)
1.1.1.30 is router, 1.1.1.1 is balance IP, 1.1.1.29 is Firewall IP address.
All function is working as expected, however, I have a host (HostA) that is configure as 1.1.1.3 and connect between the Balance and Router.
HostA can connect to internet via router directly, however, I cannot connect to hostA from the Firewall, HostA also now able to ping the balance IP and also the Firewall IP.
I have setup a Firewall rules to permit all traffic with log enable, I can see the Firewall permit the connection, but hostA still cannot access all IP behind the Balance. is there anything I’ve missed?
Thanks!
