To further simplify our online platforms for our partners and users, we will update the Peplink Training Portal to enable logging in with the Peplink ID. This will be effective as of 14th February 2022. If this is your first time logging in with a Peplink ID, you will need to create an account with the e-mail address that was previously used on the system.
FAQ
Why should I use Peplink ID?
Peplink ID allows you to use one centralized account across our active platforms (e.g. eStore, Marketplace, Forum, InControl) for logging in. Gone are the times when you needed to memorize different login credentials for different systems. This simplifies the management of your accounts for trouble-free access.
What will happen to all my access and data if I begin using Peplink ID?
Your access and data will remain the same, and only the method of logging in will change. You will then be able to use your new Peplink ID credentials going forwards.
Is it mandatory to create a new account if I have been using Google to log in?
You may continue using Google to log in if you have been using it. The Peplink ID is for those who wish to create one account for all of our platforms.
I have not received any activation e-mail from the system, what should I do?
You should receive the e-mail within a few minutes. Please also check your spam folder.
I cannot complete this process, what should I do?
Please submit your request via our online ticketing system.
Can I use the training system while updating?
Please note that there might be a downtime during the update on 14th February 2022.
