I have had several requests from clients to have an extended DHCP option for LDAP Open Directory added to the drop down for extended DHCP options. Can you please let me know if this will be possible to do or not? The client in question has a large rollout on June 8 and this extended option would be a tremendous time saver.
Thank you for your time and I look forward to hearing from you. If you need more information please let me know.
Thanks for the feature request,
We will send you a special firmware with the extended DHCP option “95” (LDAP) support for testing on next week.
May I know what is the Balance model firmware you need?
If you can get us a capture of DHCP with LDAP option used by your customer for reference check, that would be great. Then it is easier to check the support needed by the customer.
