I am so impressed with my Soho, the information out there to set it up and the forum when stuck have purchased an AP One.
It’s a lot more complicated than what I have used in the past and I don’t have a Balance in order to use AP Management.
Please could anyone tell me is it possible using a Soho to manage the AP One, all I want to do is extend the router’s WiFi to the AP…Thanks
Hello donaldd,
The SOHO does not support external AP management. The AP One would need to be configured manually or you could use InControl2 (IC2) to manage both APs. Both devices will still need to be under warranty or have an IC2 Subscription to manage them from IC2.
Thanks Zach for your reply.
