Is there a way to export Balance setting in a readable way? Handy in case import settings won’t work and manual input is required…
Hi ReexNeex, there isn’t way to read a balance file config . As workaround you can make a screenshot of the main parts of the configuration .
Maybe can you make a topic in the feature request section .
Thanks…
