Hi all,
Is it possible to export data from in control devices?
i need to export some fields like: Name, Model, Firmware Version, WAN Interfaces Speed, and some others.
Is it possible to do directly from the InControl?
Thank you.
Hi all,
Thank you.
Hi @luisalves,
You can download most of the information you require, probably with the exception of WAN Speeds, via InControl. This can be downloaded at “Organization” or “Group” level.
Here is the example from Organization level:-
Click on Settings and select “Device Management”
Then you’ll see a list of devices in the Organization (or Group), this can be exported as a CSV file, which shows more information than the device management page on InControl.
Hope this helps,
Steve
