I’m a total noob to this stuff and im not sure what to do here
I have a Peplink Balance 305 and it’s IP is 192.168.1.1 we have and IP Range set for 192.168.1.20 - 192.168.1.250
We have some devices on ips 192.168.1.10-20 that i really dont want to move.
So my problem: I need more IPs we are growing and running out of IPs with all the Cell Phones, iPads, Work stations on the network.
How would i go about expanding this range? Is it as simple as i think it is, and just adjusting the subnet mask under the IP Settings in my LAN config?
I’d prefer the IP range expand to 192.168.1.1 to 192.168.2.256? Is this possible? or will adjusting the mask to 255.255.254.0/23 expand me into 192.168.0.1 - 192.168.1.256?
Also will expanding this subnet create a disconnect for users on 192.168.1.1 and 192.168.2.1 ?
You can just change the subnet mask to /23 to have 192.168.0.1 - 192.168.1.254 as available IP’s.
Regarding the 192.168.2.x range you can change the subnet mask to /22 for them to be included. Otherwise if those are all receiving DHCP address, simply reboot the Balance and they will receive a IP from the applicable range setup in the Balance.
Once VLANs are created in the Balance, you will just need to go into the SSID settings of the AP and define VLAN 10 for the VLAN ID. Any users connecting to this SSID will receive a IP from the VLAN 10 DHCP Server defined in the Balance.
We do have a knowledge base available with additional step-by step instructions that can be accessed via the below link.
