Excluding single IP from OpenVPN
Hello all,
I have a Max Transit running V8.4.1 B5629.
I picked up a SurfShark subscription and setup the OpenVPN configuration via advanced/OpenVPN tree. I downloaded the correct opvn file for my area and setup the user/pw configuration. After applying changes, everything looks to be going thru the VPN just as it should.
I am now looking to exclude 1 IP address from that opvn configuration so that my Amazon Prime doesn’t get blocked. I tried adding:
route IP NM GW
to the opvn file but that doesn’t seem to work or I am putting it in the wrong place within the file if that is a concern.
Is there a way within the opvn config file OR the peplink configurations to bypass the OpenVPN for a single IP?
Thank you for any assistance.
James
