Ethernet Adapter for IP67
These are environmentally-sealed and rated to IP67, making them resistant to water and dust, which can destroy connection integrity.
To use an ethernet cable with a Peplink IP67 device, you will need an ethernet adapter. By using this, it will keep your device environmentally sealed to the IP67 standard.
These are the 2 optional ethernet adapters we offer:
- The ACW-657 features a plastic cap making it suitable for mating with the MAX BR1 IP67.
- The ACW-112 features a metal cap making it suitable for mating with the HD4/HD2 IP67 and HD2 Dome.
