How can I establish a connection Between a Balance SDX with Cellular WAN to Multiple UBR LTE with Cellular WAN both without a Static IP
one side will need a static ip, or you could use a fusionhub in the middle with a static ip.
You don’t need a static IP (it can be dynamic and change frequently) you just need a publicly routable IP (an IP that accepts inbound connections) preferably on the SDX in this case.
If the SDX had a public IP that accepts inbound connections you just configure the VPN in InControl and it manages the fact that the SDX IP changes.
- Thanks Martin, with the static ip, is it a Public Static IP, or a Network Private Static IP can be used?
If I have a public IP, can I connect multiple UBR LTE via Cellular WAN and Establish a pepVPN connection? Where do me manage the IP Changes in the InControl2?
