Esims broken after firmware upgrade
I upgraded my Max BR1 5G from 8.4.1 build 5474 to 8.5.0 build 5636 and after that my cellular (esim) did not come online. when I was near the router, i checked and it just did not connect. tried a few things, also rolling back to previous firmware, did not work… later i saw message that pin was wrong, entered it still didnt work.
then i wanted to delete my byo esim, did not work, added a new one, confiugured it, set the pin, nothing works… the e-sim is broken since upgrade… what to do?
Kind Regards,
Sandro Mastronardi
esim is still so new, and some things specific to your carrier, I’d open a ticket and post back here the resolution.
Well, it worked fine the first time around untill the firmware upgrade… where can i open tickets?
Hello.
Try here: Peplink Ticketing System
Thanks, just did that, will see what they say
