eSim Usage left
Hello
I am trying to find how much data I have left in my eSim plan.
Right now I only see this in the dashboard.
Peplink eSIM Data Plan (Updated on Aug 01, 2024)
Cellular 1:
15.00 GB
Cellular 2:
15.00 GB
Data usage allowance: 30.00 GB (Expiry date: Aug 30, 2024)
Also in the SFC Management I see what plan I have but not what I have left…
Thank you !
I believe the information published was captured from the router Web Admin - Dashboard, which shows the remaining quota of your subscribed Peplink eSIM, and it should sync with the SFC portal too.
As mentioned, I only see the data I bought, not the one remaining in the dashboard…
Which firmware version are you running? The remaining quota was added in 8.4.1 .
I’m also having the same experience. Is there a solution to this?
