Hello!
In new 8.5.0 firmware release notes ther’s this voice:
Added GSMA eSIM Discovery support
There is someone that can explain hoe this new feature works on Peplink devices and how to register an eSIM using this technology?
Thanks ![]()
Cristian
Hello!
Thanks ![]()
Cristian
I had the same question, is this EID provisioning support?
bump… any response here? It would be awesome to have more details around expected process here. if someone from peplink can share the details i’m more than happy to create a walkthrough.
Fully works now. You send your esim through EID then trigger the download of the esim using the discovery function !
Hi Venn,
can you please share more informations about how you did it?
I’ve not tried again for the moment but if is possible for you I really appreciate some screenshoots and tips.
For example, do you have used any other connection on the device during the process?
How much time it takes to download the profile?
Are there any logs during or at the end of the process?
It can help me and other members here to better understand this feature.
Regards,
Cristian
