Enhanced WAN Quality details for InControl2
HI Peplink Team
We at CASO are the distributor for Japan.
One of our customers asked us about a point that we thought was certain, so we are making a request.
In IC2 Reports, we can check various router logs, but WAN Quality is per Cellular.
In Bandwidth and Usage Reports, Cellular1 SIM A,Cellular1 SIM-B… etc., but the WAN Quality Report shows Cellular1, Cellular2, etc,.
I would like to be able to check WAN Quality Report as well as Bandwidth and Usage Reports up to A and B of each Cellular.
Would be beneficial when using multiple carriers and failing over, or actively swapping between two cards and wanting to investigate if one is running worse than the other.
