I live in a country where X has been censored and I have two ISP connections in my PEPLINK 20, WAN 1 is a local ISP (where there is censorship) and WAN 2 is a satellite connections where I have no restrictions. I have set up an outbound enforced policy but it is not working. Any idea what it is?
Just a silly question, but do you have both your WAN connections set as priority 1 connections? If Starlink were priority 2 for example, then it would not be active unless the main priority 1 WAN is deactivated. In that case the traffic to X would not be routed out and it would look like it is still censored.
Just make sure both the Internet source are on Priority 1 ( Dash board)
You may try to set any protocol instead of TCP
Change it to a priority rule with just the WAN you want to use in it. See if that works.
