I have a B30 Pro that I need to enable only 1 POE port. Is the POE support on the B30 Pro pass through? ie, the 48VDC is from the power supply?
I’m looking into keeping a input power of 24VDC with assumption ample amps to enable 1 POE port.
This is not possible. A 48VDC power supply is needed to enable PoE output. Thanks
Hello @abautista,
To extend on what @Tim_S has mentioned, the PoE options for Peplink Devices (once activated with suitable power supply) will be for equipment compliant with the 802.3af/at standards. If your device is using a proprietary PoE configuration (such as many security cameras and PtP links) then you are best to use that devices recommended PoE injector.
Happy to Help,
Marcus
You can do this with a voltage boost converter. It will boost your voltage from 24V nominal to 48V and then you’ll have POE out on the Balance 30 Pro.
