Pulled about 300 Peplink devices, mostly BR1 Minis or similar, into InControl. Now starting to impose order into chaos. Many of the 300 devices are already set up on a device level with LAN and SSID configurations. They aren’t all used in the same ways and a single standard configuration can;t cover all requirements, but a small handful of them that can be applied by tagging devices will work nicely, and will be easier to manage that creating/tearing down new groups.
I see that I can create an SSID and have it apply only to tagged devices. What really scares me is that we currently do NOT have “Wi-Fi Management” enabled (or checked) in the “Group-Wide SSID Settings” part of InControl. When I check it, a message pops up:
"SSID settings defined on all InControl 2 managed device(s) in this group will be overwritten by the settings below and that on the Group-wide Radio Settings page."
I have created an SSID and limited it to devices with a specific tag. If I enable “WiFi Management”, what will happen to the WiFi configuration on other devices in the group?
Will they retain their device-level settings or will those settings get wiped?
If I disable “WiFi Management”, will device-level settings be restored again, or are they permanently lost?
