Enable VPN for InControl2
For new groups I am creating in my Incontrol2 the option for enabling the VPN is not appearing.
All of my older groups have this option, but not new groups. I can find no difference between the groups as far as group/organization settings and rebuilding the new groups has no change.
Any limit that I am unaware of that would limit the amount of VPN groups I can create?
the icons are only available if you have device for that feature. E.g without a WiFi device, you will not have the WiFi Settings.
BR
In this group having issues I have 2 MAX BR1 Mini’s and no VPN option available. I added a third (same model, same firmware, bought at the same time) and the option appeared. I remove the third device from the group the option disappears again. I am assuming I have something wrong in licensing or PrimeCare has not fully gone through yet.
I will confirm with my vendor and give it a day to see if the issue resolve itself as these are new PrimeCare subscriptions.
This is still happening with all devices I have added to new groups (Balance 20X and multiple MAX Mini’s). The SpeedFusion VPN option appears after around 30 minutes so I can enable the group after I add a new device but the individual devices will not appear as selectable when building a VPN to my FusionHub. Hours later they will finally appear.
