Enable Detailed Logging, C1100T bridged to B One not connecting
How do I enable detailed logging for the WAN 1 connection? On the Dashboard, WAN1 shows “connecting…” but never goes any further.
I’ve got a new B One (thanks Rick!) running 8.4.1 and I’m trying to connect to Brightspeed (Centurylink) over DSL with a C1100T. The C1100T is in bridge mode tagging vlan 201 per tech support.
They are using IPoE not PPPoE so no credentials are needed.
Regards,
Brent
Hi Brent,
Do you mean you need to B One WAN connect using IPoE method ?
Yes. The Brightspeed dsl connection uses IPoE.
