I am trying to get my EchoLink (Amateur Radio Software) to work on my PC. My router is a pepwave Max Pro E. When I test the firewall settings this is what I get from the test.
“Local IP address: 192.168.50.10
The test successfully connected to the EchoLink server on TCP port 5200. This means that your system’s TCP configuration is correct for use with EchoLink.
The tester did not get a UDP response. If you have Internet security software installed, be sure it is configured to allow EchoLink to access the Internet. If you have a router or firewall, be sure its Port Forwarding feature is correctly set. (See Help for details.)
There appears to be a router between this computer and the Internet. A router normally requires special configuration for use with EchoLink.
If Windows Firewall is enabled (which is the default), an exception must be added to un-block EchoLink and allow it to access the Internet. (If you chose the Unblock option when you first started EchoLink, this exception has probably already been added.)
For more information, click the Help button above, or see the Firewall Solutions page on the EchoLink Web site.
Outbound Ping Test Results: FAIL”
this is what their help menu says, but I don’t fully understand it. Can you help me configure this correctly on my pepwave Max Transit Pro E router?
“Firewall Issues
Firewall and Router Issues
Background
A firewall is a system that isolates your computer from the Internet, usually for security reasons. A firewall helps prevent unauthorized access to your computer from other people on the Internet. A firewall can be implemented using software on your computer (such as Windows Firewall), or with an outboard hardware device such as a router.
A router (as used in the home) is a device which allows more than one computer to communicate over a single connection, such as a connection to the Internet. Routers have become more common in homes as home networks and high-speed connections, such as cable or DSL, have become more popular. Typically, cable companies and DSL service providers allocate only one Internet address to an entire household, in which there may be several computers. The router must decide which computer should receive each packet of data which comes in from the Internet.
Do I Have a Router or Firewall?
If you have broadband Internet service, such as with a cable modem or DSL modem, there’s a good chance that there is a router somewhere in your system. Even if you didn’t purchase and install your own router, many cable modems and DSL modems now come with built-in routers. The equipment that your cable company or telephone company provided might fall into this category.
Using Firewalls and Routers with EchoLink
Firewalls are usually configured to allow your computer to make requests anywhere on the Internet, and receive replies. Some programs, however, must be able to accept unsolicited data from the Internet. EchoLink is an example of such a program. When you are connected to another station using EchoLink, you and the other station take turns sending data to each other, so each station’s PC must be able to receive data without having requested it.
The protocol for this type of exchange is called UDP, or User Datagram Protocol. If you are using a firewall or router to connect to the Internet, you will probably need to configure it to accept UDP information on specific ports. (A port is part of an address.)
EchoLink uses UDP ports 5198 and 5199. To use EchoLink, you must configure your router to direct all incoming data on these two ports to the PC on which EchoLink is installed. Typically, there are two ways to configure this:
Forwarding. Most routers allow data on specific ports to be “forwarded” to specific computers. If you expect to use EchoLink on only one PC, configure your router to forward UDP ports 5198 and 5199 to that computer.
Port triggering. Some routers implement a smart forwarding scheme which tries to direct data to the computer which is most likely to use it, based on requests each computer has recently made. If you expect to use EchoLink on any of several different computers at different times, you may wish to try this option. Configure the router to direct ports 5198 and 5199 to any computer which makes outbound requests over TCP port 5200.
EchoLink also uses TCP port 5200. Most routers will handle these requests correctly, since EchoLink always initiates them from the local computer. If you are using firewall software, however, you may need to “open up” outbound connections to this port. (EchoLink does not use TCP for incoming connections.)
How Do I Adjust My Router?
Routers and firewalls are manufactured by many different companies, and each has its own peculiar set of instructions for configuration. Some newer DSL modems have routing or firewalling features built in. For details on how to configure your router or firewall, consult the documentation that came with your device, or the company’s Web site. Another excellent resource is the portforward.com Web site, which is a collection of instructions for adjusting specific makes and models of routers and modems. Locate your make and model of equipment on the list provided. (This site is not affiliated in any way with EchoLink, and while the information on the site can be very useful, we are not necessarily recommending the software for sale there.)
For more information, please see the Firewall Solutions page on the EchoLink Web site.”
Any help is greatly appreciated!
Thanks, David
