HI There
having two adsl lines installed on a Pep20 as a fail over with a mikrotik behind the Peplink 20 handling my wifi network
i have done port forwarding on the adsl routers through the Peplink to the Miktrotik with Dyndns on the MikroTik and all works well when a fail over happens dyndns is being updated correctly and my remote link is active at all time
problem i’m having is that my site is live and very far from me
i want to do bonding on the two adsl lines, when both wan ports are active will the dyndns stay connected or will it get confused because of the two ip addresses it now gets
has any one done this before
any feed back is appreciated
regards
kobus
