Please recommend a router that will allow me to use my Starkink cgNAT WAN and Verizon gUDP SIM. I need fast WiFi and I would like to easily be able to reprioritize the different WAN service quickly. This will be on an RV. Thank you.
Well peplink sells at least a dozen or two options
What is your budget?
Have you looked at peplink.com and reviewed the products/spec pages/compared options there?
If you have trouble doing that yourself, have you considered engaging a Peplink Reseller to help you design your network?
I asked (op) precisely because of the wide range of choices. I am willing to spend up to $500.
A reseller recommendation would be appreciated.
