I’m a new owner of a Max Transit Pro and was wondering about a couple of scenarios relating to using multiple sims.
Question 1: In the Cellular 1 modem, if I put a Verizon sim in slot A and a AT&T sim in slot B and set the setting in the details to “Both SIMS” and put Cellular 1 in highest priority, will both sims connect to their respective towers and provide cell service at the same time? Is there a way to tell which sim is serving my various devices?
Question 2: If I put a Verizon sim in Cellular 1 modem and an AT&T sim in Cellular 2 modem, can you place both in the highest priority or is only 1 allowed to be highest and the other has to be secondary? Additionally, how does it determine which sim (modem) a device would connect to?
William
