I have a number of Peplink products including various MAX Transit models, a MAX HD4 MBX and a few other things. I use WiFi as WAN on all of them with high quality outdoor antennas on boats and other floating vehicles.
My question is specifically about the MAX HD2 (non-MBX), hardware revision 5.
With other MAX products, there are two WiFi as WAN choices - one for 2.4Ghz and one for 5Ghz.
The MAX HD2 has only one, even though there are two dedicated WiFi AP ports for WiFi as WAN, similar to the other products. Is this intentional, or is there some option or flag I’ve missed to enable it?
I traditionally have used the two ports to connect to two differing WiFi as WAN sources for additional redundancy, and if the MAX HD2 doesn’t support that, I’d like to know since that limits my options.
