Hi all… I have two wifi lan extensions that connect back to a single lan interface on our WatchGuard router. They use the same subnet and gateway. I would like to add a pepwave MAX in dropin mode at the far end of each extension so that the local lan at that end would use the LTE connection on the peplink when the extension is down.
Has anyone tried this before?
