Hi.
I need to know if the MAX700 had the drop-in mode with LAN bypass. I check the configurations options but I saw only the WAN for Drop-In Mode.
Firmaware: 7.0.0 build 3310
Hi.
LAN bypass feature is available on the following models:
Balance: B305(HW2), B380(HW6) 580, 710, 1350, 2500
MediaFast: 500, 750
Thanks Ron.
In this case, if the MAX 700 be shut down the link on wan interface will be down?
Correct, however the MAX 700 does support the High Availability feature to solve this problem.
Ok, Thank you.
