I have 3 wan lines i made it work as load balance but client should see only the drop in wan ip during speed test why it sees wan 2 ip and sometime wan 3
is there any solution for it
If you use drop in mode and then have additional WANs and you want to use those additional WANs for traffic in load balancing, then internet traffic passing over WAN 2 and WAN 3 will use their allocated public IPs to access online services.
So speedtest and other internet services might see traffic from 3 different IPs.
If you only want to use WAN 2 and WAN 3 in the event WAN 1 is available you can change the outbound policy to priority instead of weighted balance.
