Download of peplink connection manager and malware warning
I have downloaded the 2.2.5 build 1027 version of the Peplink Connection Manager to use with my MAX Adapter. It was downloaded directly from the Peplink site. Both my antivirus (Webroot) and Malwarebytes warn that the installation file (6,194,640 bytes) contains malware. Webroot says “W32.Malware.Gen” and Malwarebytes says “Malware.AI.4281668776.” Is this a false alert or is there a problem with the Peplink download file? Has anyone else seen this? Thanks
Hi…
The file end is .bin ?
Never see this issue.
Can you confirm the checksum/sha256sum is correct?
Is the file digitally signed and does the signature checkout ok?
How can I find out what the checksum/sha256sum should be?
The file is not digitally signed.
