Dose the "Pepwave MAX BR1 Slim" support VPN bonding?
Hi all,
I just purchased “Pepwave MAX BR1 Slim” and wanna know if it support VPN bonding ?
We have one PPPOE + 4G SIM, want to aggregate them to speed up the internet experience.
Thanks!
Hi…
Looking at the datasheet this device support speedfusion.
" PepVPN / SpeedFusion Hot Failover " can be read at datasheet.
I also… check at Peplink Online Shop and don’t find any separated license to buy and do the speedfusion activation.
Take a look at your device.
Dashboard > Advanced
Can you see SpeedFusion VPN label at the left side?
Hello, Thanks for your advise.
I do see the feature, but there seems no any option for Traffic distribution as Bonding?
This is my unit config page:
Below is what I am gonna want but can not find it, below is captured from another different model peplink unit.
Hi…
Maybe because your firmware it is too old.
But… you have speedfusion.
Look the Wan Smoothing… “normal”, you also have FEC.
and below… you already selected priority highest for pppoe, 4g and wifi.
Just leave your old device at normal and the new device at bonding… you will be fine.
I am using fw-max_br1_br2-8.3.0-build5256 .
That is the latest and only downloadable firmware , is that still “Old” ?
If the peer site also the same model and Firmware, does the bonding work?
hi…
Yes… the last version, not sure for your device, it is 8.5.1.
I have a very old br1 (6.3.5) in a speedfusion with mfa-hd4 (8.5.1) and the speedfusion tunnel is up.
Also I have devices (tst-duo) running 8.0.2, doing speedfusion with mfa-hd4 and bonding work very well.
Screenshot 2025-01-08 06.06.45
