Dome Pro LR - Supercharge Your Maritime Connectivity
Sail away from familiar shores, yet always stay connected.
Leverage a dual 5G cellular router and high-gain antennas within a single enclosure, supporting virtually any band around the world for global long range connectivity.
Discover its versatility and power of pairing different connectivity options, whether you’re a vessel owner, crew member, or passenger.
With the Dome Pro LR, maritime connectivity reaches new heights and extends over greater distances.
Learn More
Any chance docker support can be enabled in the firmware? Or it doesn’t have the memory in it to store docker?
Hi PG,
Dome Pro LR doesn’t have additional memory for storing dockers and therefore we can not enable docker support.
Does it have the slot on the PCB?
no, the slot is not available as well.
