Dome Pro LR - mounting options
Are any of the existing Peplink deck mounts suitable for use with the Dome Pro LR? Or could anybody recommend a suitable basic mount that is no taller than 100mm or so?
Is there any info on the mounting options for the Dome Pro LR? I am looking to pole mount this unit on top of a 2-inch rigged, but I can’t find info on the mounting options.
Would like to see people’s go to’s on this as well.
I know Seaview has some stuff.
