FusionHub is the virtual SpeedFusion appliance from Peplink which allows you to establish SpeedFusion connections between cloud servers and physical Peplink devices.
Installing your FusionHub instance is even simpler than before; to expedite License activation a reboot isn’t required regardless of circumstance. The only requirements to this is if the FusionHub is connected to an InControl Appliance, the ICA Firmware need to be on v2.5.2 or greater and the License also needs to be online in InControl 2.
If your FusionHub is not tied to an InControl 2 Appliance, make sure that the FH Instance is on Firmware 7.0.1 or greater.
