Does anyone know if running Docker containers will be coming to the MBX?
Good question - seeing that it just appeared on the BR2 Pro 5G in 8.3.0 in beta, I have the same question. Given that the MBX is 2-4x more expensive, I would really hope it is planned.
Yes in 8.3
Docker :
MAX BR1 Pro Dual HW1
MAX BR2 Pro HW4
MAX Transit Pro series
MAX HD1 HW4
MAX HD2 HW7
B20X Pro
Docker and KVM:
MFA500
MFA750
Balance 2500 EC (upcoming)
MAX HD2 / HD4 MBX with MediaFast
PDX HW3
PDX Dual HW2
PDX EC / PDX EC Dual
SDX Pro
What are the MAX BR1 Pro Dual HW1, and B20X Pro, is there more info about these new types?
Do the mentioned units with Docker support have some form of internal storage for the containers, or can you use USB storage for that?
No idea for these devices, maybe tentative product.
docker use internal sdcard like in the Transit pro.
is there a full up-to-date list?
what is the b20x pro? did that product ever get released?
is the regular b20x or b one capable of running docker?
the br1 pro cat 20 or br1 pro 5g?
thanks
Hiā¦
Try the url compareā¦
Sample⦠Peplink.com - Model Comparison
search for
Edge Computing Yes (Application/Docker/KVM)
under Featuresā¦
