Using a MAX On-The-Go and I already have a dns registered with DNSdynamic but they are not listed in the drop down menu. On other routers, they had a custom option that I used. How can I use my existing account?
We only support the Service Provider listed in the drop down menu. You may post your request at Peplink | Pepwave - Forum.
Thank you.
