I use a peplink balance one core as OpenVPN server to access the local network of my enterprise. I have a local web server and i need to work on it from this openvpn connection. I 've added the local dns record in DNS proxy settings
When i use the local IP of the web server, i can join it but when i use the name it’s not working. It’s working from the lan.
When i do a dnslookup of the name, my laptop (OpenVPN client) give me the good ip of the web server but not possible to access it with his name on a web browser .
What can i do ?
you were right ! i 've changed the hostname from xxxx to xxxx.local on my server then i made the modification on the pep and it’s working now. Thank you very much, you can close the ticket.
