I’ve successfully established an IPSec VPN connection between my Balance 20 and Balance One.
The Balance 20 uses 192.168.12.0/24
The Balance One uses 192.168.11.0/24
Two Questions:
- On the Balance 20, I have a server with a DNS record, server.example.net 192.168.12.3
I’d like to be able to setup the Balance One so that server.example.net would resolve to 192.168.12.3. I tried entering this information as a local DNS entry on the Balance One, but it did not work. Is it possible to do what I’m looking for, or is there something else that I need to setup to make this work?
- Is there any way to make it so that the computers on each end of the VPN show up when you browse the network on MacOS?
Below is the recommendation:-
Having Active Directory and DNS server (Recommended and this is a proper way)
Configure L2 SpeedFusion between these 2 sites.
- This will make 2 site having same subnet. Thus you will able to access by hostname.
- Disadvantages:-
-> You have to change IP subnet at 1 site.
-> ensure the new subnet can cover all all devices.
-> You will having problem if you have multiple sites in future and run in same way.
- Add all remote host names in Local DNS Records
- You have to add all remote host names. You have to do at all sites.
- Disadvantages:-
-> Very troublesome if you have multiple sites.
-> Host name cannot can’t be resolve if user change the host name.
Again, you are advised to have AD and Internal DNS based on your requirements.
Hope this help.
