I have a Pepwave Max Transit LTEA that came as part of the Airstream Connect implementation. It is running firmware release 8.2.1 build 5372. I am trying to get WiFi WAN set up to connect to my home network to avoid the use of a limited cell data plan. My home network is a Ubiquiti Unifi Secure Gateway (USG) and two APs . The ISP I use is a DSL service through CenturyLink.
When I enable the WiFi WAN on the Pepwave I am able to connect to my home network just fine. The signal is good since I have it sitting in close proximity to an access point. As a router WiFi client I can connect to anything on my network through http, SSH, FTP, etc. and I can ping public IPs like Google DNS. But when I try to browse to a public web site I get an ip not found error. I have tried this on several devices with several browsers and noticed that the Chrome and Google browsers return a DNS_Probe_Finished_Bad_Config error. I can successfully navigate to the same sites on the same client devices when directly attached to my network WiFi. I have also so I assume there is some setting (or lack there of) in the Pepwave that is causing this.
I have been through the DNS and WiFi console settings and nothing jumped out at me so I am uncertain what information would be valuable here but I am new to the Pepwave product and management console so any help I can get to identify the source of this issue would be helpful.
Addition: below is a snapshot of the WiFi configuration… should there be something listed in the DNS fields? I would have thought that the ISP DNS server addresses would show here.
