It would be useful to be able to see the WAN and WWAN status in the list view of icontrol, so that at a glance you can see if a site is on backup.
Thank you for the suggestion, we will discuss it internally here to see if this is something we can easily implement on future updates.
I would like to push this issue. It would be very useful to see wan/cellular status in the grid view of incontrol. so at a glance you could tell if a location was on backup.
In TKâs screenshot, some major information are already provided. E.g. WAN name, state, carrier name, priority, signal strength, etc. What sort of information you also want to see at a glance? (Iâll put aside whether it is in grid view or not so long as the screen could clearly provide the necessary information at a glance.)
Ok â so what I am asking for is that while on the grid view page, now you can see if device is online or offline. I would like to be able to see if the device is on cellular or WAN.
Oh I see. You want to see what active WANs are on the device list without drilling into device details. Let us get back to you later.
We will add a âWANâ field to the device list. A few small Ethernet WAN, cellular WAN and Wi-Fi WAN icons in same size as the red/green status indicator will be put into the field to indicate the active WANs. Each icon indicates each WAN. Hovering over a WAN icon will display a tooltip of the WANâs details. What do you think?
Yes, that is exactly what I would like to see.
We will add the WAN field in the next major release.
Would be wonderful to just have a page that just shows WAN outages at the organization level. As an MSP with hundreds of Peplinks deployed, we can no longer rely on email alerts or drilling down into device details to address these efficiently.
We have the info in âGroup device list viewâ and that should summary the devices status. Detail info please check screenshot as attached.
This isnât very helpful.
A. Weâd have to drill down into every customer to see their WAN status at any given time, thatâs why I said the organization level. That screenshot is a display at the group level.
B. I just pulled the secondary WAN connection on my home Peplink and the InControl dashboard now simply shows that I have one WAN connection rather than a failing second WAN connection. Thatâs pretty deceptive.
An effective dashboard for us would have an outage list, like any NOC would have, so we can address WAN problems from one single view, not have to go through 25 different customer screens, and certainly not have a dashboard that makes the devices look like they only have one WAN connection when they might actually have two WAN connections but one happens to be down.
A good idea but weâd need to limit which WANs will be monitored in this way. We have many multi-WAN devices where not all WANs are connected (ie a B710 with only two of the 7 available WANs active).
What this would need is the ability at a device level to identify WANs that need to be monitored for outages in this way (ie the ones weâd expect to be live) - perhaps a checkbox next to them labeled âMonitor Availabilityâ.
Then I would suggest at the organisation level a summary box that shows the number of monitored WANs that are down. When clicked, that gives a list view of devices with WAN outages (showing any other live WANs that may exist) so you can quickly see which sites need some investigation.
Hey Martin, I was thinking the outage board wouldnât show connections in âCold Standbyâ mode as outages, nor things like mobile connections that are scheduled to be turned off afterhours - only devices with WAN connections set to active that were no longer functional.
But an option to tag or mark devices / connections that exclude them from appearing in the outage list would definitely be helpful, since we have devices like lab routers and loaner equipment that we wouldnât want to appear as alerts.
