Disabling Two-Factor Auth in InControl
Greetings, I’m trying to disable two-factor authentication in the InControl app and it just doesn’t work. Every time I go in and disable it, when I try to access that group, it tells me it requires two-factor auth and wants to set it up.
I need to get two the accounts devices and delete so I can create a new account with different email addresses.
Any ideas here?
Not sure what you’re trying to say here, but if I may offer some advice - rather than spending a bunch of time trying to defeat protection mechanisms (such as MFA) designed to keep your system/s, device/s, account/s, network/s, etc. secure, why don’t you direct that energy toward finding a way to adopt them? If your concern is shared access, I’ve found it to be pretty trivial to set up two or more devices (typically phones, but could also be tablets or even password managers) with the same MFA key.
