Hi friends
on BPL-710 HW-3 Firmware 8.5.2 build 5381
how i can disable Web Blocking
Harel
i had enable but it start making false possitve blocking
and i need to add Exempted Domains from Web Blocking
and it keep happening .
now i dont need hit my LAN is protected with Checkpoint
i need to disable it completly
i try the exempted subnet
i find a bypass i check ALL in Exempted User Groups
now its ok
We also found out, that Web Blocking bricked the Backblaze B2 cloud sync from our QNAP NAS.
We only enabled the „Malware“ blocking category but this lead to errors of HBS3.
Example:
Message: [Hybrid Backup Sync] Failed to complete Sync job: “DR_FILES_TO_B2”. Cloud storage service unavailable. Try again later, or contact your cloud storage provider for details.
When we exempted the NAS VLAN all cloud sync jobs worked fine again. IMHO the Peplink block list needs to be corrected!
See ticket [26050058]
