it would be nice to disable WAN from IC2. the reason is that sometimes a WAN circuit might be running slow or so slow that I can’t remote into the router, however, the other wans are working just fine. If I could disconnect and reconnect via IC2 we could potential gain access to the routers.
We are adding the ability to change WAN priority in IC2 with drag-n-drop, like the web admin for MAX. One of the priorities is “Disabled”. Stay tuned!
Is there any update on when this feature will be available in IC2?
We are currently working on configuring a number of MAX Transit Duo devices via IC2. Having the ability to change WAN priority in IC2 with drag-n-drop would be very helpful. Thank you!
