I have a MAX-BR1-PRO-5GD-T-PRM that only has cellular internet connection and i want to be able to disable NAT on 1 of the 2 LAN ports as i need there to connect a VoIP endpoint device does not operate ok when going through NAT.
On the other LAN port, the devices that are connected should have NAT.
I am reading about the IP Passthrough but i cannot understand how how to make it work on a single port only.
Thank you very much in advance!
