I am trying to find a way to disable all APs in a Group of Max BR1 minis. From time to time a Tech will enable an AP on a Max BR1 for troubleshooting a system, but will forget to disable the WIFI when they are done. Is there a Group Policy setting I can use to disable the BR1 Minis AP after so many hours, or at a particular time each day?
An enable for x minutes would be perfect
Kind of like on SpeedFusion tests you can disable certain WANs but they are auto re-enabled after 15 minutes
