Some devices will be deployed at locations where they are not able to be located in physically secure locations. We want to be able to disable/deactivate any unused physical ethernet interfaces.
Thank you.
Dana Konkin
Thank you.
Dana Konkin
For example a B20 has 4 x LAN ports, you want to selectively disable the LAN ports, such as disable port 2, 4?
Yes that is what I mean. Thanks
Thanks. Can you specify the first firmware release it is supported in and on what models of hardware please?
Regards,
Dana
This is supported since v6.3.0.
Thanks TK,
Cheers
Dana
