I have installed an external antenna with the BR2 Pro that is just strong enough to go through the roof and cause interference with the AP One AX Lite.
Is there a way short of unplugging the cables to the external antenna of disabling WiFi only on the Router while allowing the AP to broadcast as usual?
Thanks in advance for any advice.
Ray
